CrustyHK Offline
#1 Posted : Sunday, 5 June 2011 8:16:17 AM(UTC)
CrustyHK
Byron did you ever follow through with trying to fit up an Cressida steering box to K-T-G ?
I've noticed a few of them around the pick-A-part yards and they sure have some similarities.
Peter
peter_flane Offline
#2 Posted : Sunday, 5 June 2011 9:00:21 AM(UTC)
peter_flane
I have fitted one to the EH Limo. It works, but does not just click in like a piece of Lego.
Dr Terry Online
#3 Posted : Sunday, 5 June 2011 5:09:40 PM(UTC)
What he said. ^^^^
#4 Posted : Sunday, 5 June 2011 7:19:19 PM(UTC)
I did place it against HK rails and it will fit but will need significant work and probably Engineering.
CrustyHK Offline
#5 Posted : Monday, 6 June 2011 3:10:59 AM(UTC)
CrustyHK
Is it worth doing or is there a better way to go ie R&P instead?.
#6 Posted : Monday, 6 June 2011 4:40:42 AM(UTC)
Depends on how good you are with metalwork. Either need Engineering. At least with the Cressida box you'd not get bumpsteer issues. I think I did hear that you needed to get a HK steering arm respline dto fit the Cressida spline. One of the mounting holes appears to line up. The other two need work. The power steer hoses come out of the top of the box so will look a little messy. I have one here in the shed to compare, but you should find one for less than $50 locally. The Cressida this one came out of was a 1981. The square ugly rear drive cars with small OHC 6cyl and 4spd auto. I think they ran from 1980 to about 1984
CrustyHK Offline
#7 Posted : Monday, 6 June 2011 5:06:31 AM(UTC)
CrustyHK
The metalworking side of it will be Ok. The conversion should be a massive improvement on the ram steer.
I spotted an early 80's Crown today. It's almost identical apart from a speed sensitive valve on top for variable PS that picks up its signal from a hall effects sensor. I ran out of time and didnt see how the sensor is mounted yet but it could be just run off the tailshaft.
#8 Posted : Monday, 6 June 2011 6:12:51 AM(UTC)
