monman71 Offline
#1 Posted : Saturday, 18 June 2011 5:53:19 AM(UTC)
monman71
Hi All,did holden in the 70s when stamping engines and sub frames do it by heat?i am asking because if a number was grounded off and restamped i would be able to get the original numbers by the heat marks under the paint?Cheers
#2 Posted : Sunday, 19 June 2011 5:15:14 AM(UTC)
in the HQ-WB series the chassis numbers were stamped by a machine (rolled on)
i'm unsure about the engine numbers but i'd imagine they were done the same way
no heat was used
to find a number you can wave a oxy torch over the area and it'll (sometimes) show up briefly, this works really well on blocks that have been decked and the number was machined off
