ht1970 Offline
#1 Posted : Friday, 24 June 2011 7:22:23 PM(UTC)
ht1970
Hi, iam looking to buy a ht gts monaro coupe 80837 brisbane built date on tags 2/1970. Wondering if it is the original engine # 308H119** K19 and did 308 only ever only come with a chev 10 bolt option when behind a saginaw. What is the original ratio for the 308 saginaw. Any input would be much appreciated. Thanks
dirty davo Offline
#2 Posted : Saturday, 25 June 2011 4:10:54 AM(UTC)
dirty davo
2.54 first gear ratio
regards DD
The HKTG Garage Offline
#3 Posted : Saturday, 25 June 2011 4:57:06 AM(UTC)
The HKTG Garage
Yes, 308 manual had a Salisbury 10 bolt. KI9 = 1st October 1969. Saginaw ist gear ratio as above. One notch on input shaft.
