#1 Posted : Wednesday, 26 May 2004 9:12:43 AM(UTC)
Just wanting to know if anyone can tell me how easy to change a hx 308 from auto to manual.Is it feasable or not and if so what are the finer points needed to achieve same....Thanks
#2 Posted : Wednesday, 26 May 2004 6:33:24 PM(UTC)
Depends on the manual box you want, and whether yours is a TH350 or TH400. Easiest conversion is an M20/21/22 or a 3-speed. You'll need the following:
CRS bellhousing;
Trimatic/4-speed/3-speed crossmember, speedo cable, tailshaft and yoke;
Flywhee
#3 Posted : Thursday, 27 May 2004 4:35:46 AM(UTC)
Hi Guys.
Everything Byron has listed is spot on, excepting TH350 were not fitted to HXs.
Just one question though, why would anybody take out a perfectly good TH400 box to fit a manual cogbox ?? Stay with the auto, last longer, less hassles &a
#4 Posted : Thursday, 27 May 2004 7:54:03 PM(UTC)
Personal preference is pretty much it. I grew up with a manual in the Torana, and wouldn't swap it, as I thoroughly enjoy driving the manual, and it's part of the original car setup.
Any other old holden projects of mine will probably also be manua
#5 Posted : Friday, 28 May 2004 3:39:51 AM(UTC)
Yeah I know. But I added the TH350 just in case someone had changed it. I suppose I should have added the case that it is a trimatic now also. It's happened to me plenty of times where I go to look at an 'original' car, only to find it's a HJ with HZ ID a
