The image in that rarespares link (part no. LRS1016) only shows the plastic lens and gasket. Dont see anything else?
The housing (which has the socket for the globe) is a seperate part. I like your idea though, would need a bit of fabrication, etc. I guess. |
___________________________ WTB: - HQ-WB(?) bench seat 4-speed shifter - HQ-WB ute rear window - HQ-WB standard rims - HQ-HX coupe front windscreen mouldings - HQ-HX coupe door mouldings (the stainless one running along top of door exterior) |
ok I thought that aluminium thing around was the housing. Can't find the housings anywhere. I was thinking insted to go with those http://cgi.ebay.com/ebaymotors/...ries&hash=item19b43a6a21but I'm not sure if they have amber versions. |
"I killed the Bank" Andrew Jackson, last words |
There are also these: http://www.billetspecialties.co...p?cid=6&scid=192&pid=327not sure which ones I should go with. Which ones would you guys go with? Edited by user Saturday, 23 July 2011 10:12:47 AM(UTC)
| Reason: Not specified |
You already own a set of tail-lights, why not just connect the reverse lights up. If they are there they need to work for roadworthy. Either that or just fit some aftermarket red & amber assemblies & wire them as per original. I though the whole idea was just to get a roadworthy, why bother with cheap looking billet crap.
There are plenty of LED assemblies on the Australian market designed for trucks & trailers & they also surface mount, which make for much easier fitting.
This is one place where LED lights are great.
Dr Terry |
Yeah I agree with D.Terry,led's are the go there (for me) |
Jim in Adelaide.. |
yeah sure i need a roadworthy, but i also want proper tail lights, and the 10 dollars ones that are on now just look terrible. So I'll most likely get some original HQ sedan ones and mount them directly under the tray. |
