Gday, Can anyone tell me if they know of or seen what i have today. Under the bonnet where the bonnet catch is bolted, on the passenger side looks to be a large holden warranty rivoted to the apron which reads if speeding holden warranty is voided, something along those lines anyway, something i have never seen or heard of looks to have been there since new. Any feedback would be great Cheers |
Nessyhk Built not Bought |
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
Possibly off a commercial? |
commercial as in advertisement or light truck it also has a brand new nasco air filter cover |
This is what you would have seen ,they use different weights between utes/vans and Early Holden Commercials have them also , again with different load weights . They are riveted to the locking panel using ID tags type rivets. http://www.ebay.com.au/i...ries&hash=item256512fbb7Edited by user Sunday, 24 July 2011 8:03:29 PM(UTC)
| Reason: Not specified
thats exactly what it was thanks sebring good to see an old hk ute with this still intact something different, ill be making sure it wont be removed |
Commercial as in ute/van. ^^That is what I was referring to. |
ya not quite on a goldmine there nessy. every ute & van had em standard. id have at least 10 of em. sure simon would have a bundle of em too!!! regards DD www.bellarineclassicautos.com.au
Almost. To my knowledge they were deleted on appearance of the ADR Compliance plate (1/1/70). The commercial load rating (GVW or GVM) is stamped on that plate. Dr Terry |
Almost.
well there ya go!! thanks terry i just scrounged thru mine & found 6. plus 3 still on top locking panels. & all relate to HK or early HTs regards DD www.bellarineclassicautos.com.au
