28 Pages123>»
the eh Offline
#1 Posted : Saturday, 3 September 2011 6:17:00 AM(UTC)
the eh
This is my EH. It's taken 21 years to get on the road. I tried to post pics here but couldn't get it to work.
http://gallery.oldholden.com/myehholden/
Edited by user Saturday, 3 September 2011 6:19:44 AM(UTC)  | Reason: Not specified
the eh Offline
#2 Posted : Sunday, 4 September 2011 5:04:38 AM(UTC)
the eh
If anyone can tell me how to post pics I will do so. I have tried half a dozen times but with no success.
the eh Offline
#3 Posted : Sunday, 4 September 2011 5:13:52 AM(UTC)
the eh
I have tried to post a pic by clicking the "Insert Image" icon above then pasting into that the URL of the picture from my OLD HOLDEN page. I've tried it with the .html removed from the end and also with it still there. Neither works. HELP
#4 Posted : Monday, 5 September 2011 7:14:46 AM(UTC)
Hey Scott
Just right click on the photo you want to post from your shed, and click properties.
Then copy the address from the preperties screen.
Click insert image above and paste the URL between the two img's that come up and Bob's your aunty Mary.
Edited by user Monday, 5 September 2011 7:18:07 AM(UTC)  | Reason: Not specified
 1 user thanked jpb308 for this useful post.
Smitty2 on 14/05/2020(UTC)
the eh Offline
#5 Posted : Monday, 5 September 2011 7:22:56 AM(UTC)
the eh
OK here goes
the eh Offline
#6 Posted : Monday, 5 September 2011 7:24:08 AM(UTC)
the eh
YeeHaa it worked. Now I know what to do I'll add a few pics here. Thanks Jeremy
the eh Offline
#7 Posted : Monday, 5 September 2011 7:38:22 AM(UTC)
the eh
This is how it arrived in 1989
This is going to the engineers for the first inspection
Now it's off the the panel shop for the first time
Back from the panel shop after being painted underneath and the ehngine bay. Now it's time for assembling the drivetrain
Home fron the panel shop after final paint. The front end is too low and was raised with standard height HG V8 springs
Now all finished it's back to the wieghbridge and final engineers inspection.
All finished and ready for rego
Registered finally. I had the plates on holde at the RTA for 8 years
#8 Posted : Monday, 5 September 2011 7:39:22 AM(UTC)
No Problem Scott
And welcome to Fastlane.
I think you'll enjoy it here.
the eh Offline
#9 Posted : Monday, 5 September 2011 5:37:59 PM(UTC)
the eh
Here's the engine.
The final specs are 4 bolt block bored to 30 thou and fitted with SRP 12cc dish forged pistons on balanced late Holden rods all connected to a 3.48" stroke Scat crank. Cam is a Camtech CT2248-49901B-110 hydraulic roller cam with speedpro lifters and original Holden lifter retainer. Heads are Yella Terra dash9 alloys machined to give a 55cc chamber and 10.5:1 compression ratio. Valve collets were changed to suit the roller cam and coil bind occurs at 700 thou lift. This cam only produces 587 thou so plenty of margin there. The cam was installed 2 degrees retarded using a JP timing set. A High Energy HQ style oil pan is used with an SRA oil pickup and standard volume JP oil pump. The inlet manifold initially will be the 8 throttle body unit but I may change this to the Torque Power high rise dual plane at a later time.
the eh Offline
#10 Posted : Tuesday, 6 September 2011 4:11:29 AM(UTC)
the eh
Braking system is a VT Commodore fast fill master cylinder mounted on an XE Falcon booster, with 355mm Corvette C6 Z06 rotors and front calipers. Whilst the rear is 343mm Harrop rotors with Corvette C6 Z06 calipers
Front Calipers
BW78 with Corvette brakes adapted
Summit Racing billet brake vaccum pump is needed as the inlet manifold and cam combo don't give me a reliable, strong vacuum source
Master cylinder and booster.
Front rotor and hub assembly. Still needed final machining of the spacer in this picture
Rear brakes and diff fitted
the eh Offline
#11 Posted : Tuesday, 6 September 2011 6:46:54 AM(UTC)
the eh
Interior
seats and VG ute/ HQ style handbrake lever
Dynamat everwhere
VR-VS level 3 instrument cluster modified to fit in the original EH dash housing
the eh Offline
#12 Posted : Wednesday, 7 September 2011 6:41:08 AM(UTC)
the eh
Paint and Panel from the beginning
#13 Posted : Saturday, 10 September 2011 6:06:57 AM(UTC)
Very Nice!!!!...nothing else needs said except!!lovely!
greenhj Offline
#14 Posted : Saturday, 10 September 2011 6:21:49 AM(UTC)
greenhj
Was thanked: 14 time(s) in 12 post(s)
damn thats a nice car!
the eh Offline
#15 Posted : Saturday, 10 September 2011 5:29:31 PM(UTC)
the eh
Thanks guys for the kind words...
the eh Offline
#16 Posted : Saturday, 10 September 2011 5:40:07 PM(UTC)
the eh
There's the rear end. It's a Borg Warner 78 3.08 LSD. Narrowed Ford EF housing as this has better caliper mounts than the Holden unit. Also allowed much easier handbrake setup. Now the car is on the road the 3.08 gears don't give me the kick in the pants I want so they are coming out and some 3.89's are going in.
Here it is in the initial mockup. All fitted well so it's out to be detailed
Spacer machined to allow my HQ application wheels to fit on the Falcon axle. The axle flange on the diff is 70.2 mm but the wheel centre hole is 73.2mm. This fills the gap and neatens things.
Hand brake backing plate and caliper mounting is nice and strong and a heap better than the Commodore version of the diff. This is why I started with the Ford unit.
the eh Offline
#17 Posted : Saturday, 17 September 2011 7:04:56 AM(UTC)
the eh
Wilson Nitrous pro flow direct port dry nitrous kit. This should look sweet plumbed into the throttle bodies and if set up correctly hopefully add an easy 200 or more horsepower.
Inlet manifold burst panel hopefully will save me money in the unfortunate case of a nitrous backfire. This should prevent damage to the throttle bodies, MAP sensor, pressure regulator
Nitrous bottle mounting bracket. It's compact and easily adjustable for angle. It will be removed when the car is used on the road. The bracket is removable with just the small mounting plate staying in place. It will be covered by the spare wheel.
Nitrous line was routed up under the passenger side inner guard out of harms way. Once it was mounted I removed it and wrapped it in a nylon sleeve that also houses the solenoid wiring and the wiring for the dakota digital sender units.
This is how the nitrous solenoids will look when mounted. There are mounting tabs on each of the the air filter front mounting plates. These tabs will hold a mounting plate which holds the solenoids and plumbing.
the eh Offline
#18 Posted : Monday, 26 September 2011 11:53:35 PM(UTC)
the eh
Nitrous kit install progress. All finished other than some fittings I need from the US. Whilst I'm waiting I'll rip everything apart and have the welding done on the manifold and then have it aluminium sprayed..
Nitrous blowback burst valve will be mounted at the front of the manifold on the plenum. Each throttle body is ported to the plenum by a 6mm hole. This should allow the plenum to pressurise and the valve to release this pressure in the case of a nitrous or any backfire.
Combined dual nitrous distribution block and throttle body linkage housing. The nitrous block supplied with the kit are works of art but didn't suit my setup. This one will keep all the pipes relatively short and equal length.
Nitrous nozzle pipes run. I still need the connectors to connect these pipes to the distribution block.
All the nitrous plumbing sits in the valley. With the air filters in place most of the plumbing is hidden.
Nitrous setup finished. Now it will be pulled apart and the inlet manifold will be sent out for JET HOT coatings in a brushed aluminium finish.
the eh Offline
#19 Posted : Tuesday, 4 October 2011 6:46:19 AM(UTC)
the eh
Front end pictures..
HR crossmember from CRS. CRS lowered stubs. Kings springs from HK-HG V8, Monroe shocks, Torana steering rack with custom mounts, powder coated black. Custom adjustable Whiteline front and rear sway bars. Superpro bushes throughout the whole car.
Assembled front end. All powder coated, painted, chromed and polished..
Adjustable front stabiliser bar ends. This, along with the rear bar, were custom made by Whiteline for me.
I am replacing the rubber/urethane front crossmember insulators with machined aluminium versions. This removes the play between the crossmember and the chassis. It does allow more vibration etc to be transferred to the chassis but luxury is not my aim, performance is.
Steering shaft uses Torana uni joints. Rack is a front mounted Torana.
Crossmember to subframe nounts machined from aluminium instead of rubber or urethane.
Lower ball joint covers neaten things up.
Billet aluminium Steering column cover. This will cover all the steering column visible in the engine bay. Looks much neater.
Bruvpig Offline
#20 Posted : Tuesday, 4 October 2011 8:28:35 PM(UTC)
Bruvpig
Hi Scott, that is going to be a sweet ride indeed, hope you keep hold of it forever.
What are the specs on the front brakes? is that an adaptor plate on the caliper mount?
Brian
Stepping stone or stumbling block...your choice
Guest (7)
28 Pages123>»
This page was generated in 0.366 seconds.
