peter_flane Offline
#1 Posted : Friday, 30 September 2011 8:08:11 AM(UTC)
peter_flane
I am after stub axles and hub assembly part numbers for VR non ABS.
I seem to have found so far
9208 4559
9208 4562
Hub 9211 5770
Is there any real major difference between ABS, non ABS, VS, even VT ?
#2 Posted : Friday, 30 September 2011 3:59:14 PM(UTC)
VR/VS are the same as each other, but different to VT.
There's 3 types:
1. Non-ABS
2. ABS with live axle
3. ABS with IRS
The pulse count out of the 2 ABS ones is different, so that they can match the differing pulse counts frm the rear.
As you don't have ABS, you can use any of the 3 - you simply won't have the wire to plug into the sensor on the back of the front hub.
