quote: Originally posted by Mr Bob Dobalina
Davo, make sure you explain to Ross that we will require him to sign a non-disclosure agreement, all scans belong to our group and cannot be used to manufacture for any other party and any product produced including samples cannot be supplied or sold to any other party. I will have the NDA drafted up by a law-talkin guy.
MOST DEFINITELY
anyone add their name to woodgrain group and details of what you can provide. I propose equal access to the intellectual property by all members. If you don't want your name on this list please remove it Brian - HG sample Davo - HT Sample + liaise with Ross Sebring Orange - Technical support xxxx- HK woodgrain sample Simon - product support Dobalina - part finance / administration by proxy edit: access to Intellectual Property is defined here as access to stock at group cost. Please keep records of your expenses as these will define group cost. Edited by user Sunday, 6 November 2011 7:24:41 AM(UTC)
| Reason: Not specified
Delete me if you dont mind , i just give out ideas and help for free when required . You have another hurdle you have not thought of though. Gotta find out how it was adhered to the metal backing 40 years ago . My guess it was done by a HF Welder or heated so only the backing melted to the steel plates but no one seems to know ? Its not a glue that i can make out , as i have done quite a but of testing with knowledgable people over the years and glue does not work and just bubbles up . Super Thin film double sided (sticky) Aircraft film works great , bits still not how it was done . Hence why i almost think making it as a Kitchen type Contact Adhesive film type thing maybe be more cost effective and easier 40 years later for the low volume rather than making it how it was way back . Although you always know if its done how it was 40 years ago you will get the same result.
Just my thoughts John Boy
Thanks John Boy, deleted as requested, we appreciate your input. Hopefully we can make you an honorary member of the hktg woodies down the track
Brian - HG sample Davo - HT Sample + liaise with Ross xxxx- HK woodgrain sample Simon - product support Dobalina - part finance / administration by proxy
I would agree that it doesn't appear to be glue as it isn't affected by the common range of solvents so we can look into that and/or decide that contact adhesive will meet our needs.
I have only looked at it in a cursory manner so far and have noted some basic effects which appear to support your observations
Joined: 16/09/2010(UTC) Posts: 410 Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
Hey Bob Dob, contact me re who does it etc. A leading trim restoration place in Adelaide has been doing the woodgrain for these models for years. In fact I'm 95% sure they are the ones who supply/or supplied rares originally. From as far back as the mid nineties, well before rares had it available as one of their product lines. In fact you can walk into this place today with you HK glovebox woodgrain and they'll do it for you to match the rest. Exact same stuff. Same process. They are the ones bringing it in and they know how to adhere it to the metal pieces. Weird how it's not available in the rares kit but this mob can do it for you if you bring your glovebox piece in. If you found or made a better matched reproduction woodgrain then maybe you could strike a deal with them so they use it on theirs in return for knowing how it is applied. Rares probably are'nt totally to blame as they would of seen someone doing it tied up a deal in supplying them because the trimmer would of convinced them it was the best he could find and uses it on his big dollar Monaro interior restos. They dont have to do the research and voila! close enough is good enough Edited by user Wednesday, 22 February 2012 5:30:32 AM(UTC)
| Reason: Not specified |
The HKTG Garage. The Home of HK HT HG Holden. |
yes whats happening as im very keen on these better copies trim thanks luke
will get onto this into th new year still need a nos or perfect sample of HK woodgrain to complete th set b4 we can progress. im sure simon can complete th missin link (hk sample)& will get this all sorted later in january or feb (not gun happen overnight, but it WILL happen regards DD www.bellarineclassicautos.com.auwork commitments & xmas approachin too quickly etc have made this project unreachable this year
so how long we talking before production?6 months?a year?
regards DD
Did you do a deal with Rare Spares DD???? These new glove box inserts are unreal mate!!! All this talkin has produced some parts that we all can use. Cheers, Brentos Chap.... http://www.rarespares.ne...Page.aspx?product=WG1015
They are still made from the completely wrong wood grain unfortunately , but at least its matches all the other wrong ones you buy to make a set now . Dave is talking about making the whole lot with the correct woodgrain next year some time , so he not cut a deal with Rare Spares.
Thanks: 1 times Was thanked: 487 time(s) in 464 post(s)
regards DD
Davo If Simon can't help I have the following NOS HK woodgrain that may be available for reference. I'll talk to you via email. Radio blank. Premier 6cyl dash surround. Glovebox strip. Steering wheel. |
quote: Originally posted by HKTG Parts Recovery
Hey Bob Dob, contact me re who does it etc. A leading trim restoration place in Adelaide has been doing the woodgrain for these models for years. In fact I'm 95% sure they are the ones who supply/or supplied rares originally. From as far back as the mid nineties, well before rares had it available as one of their product lines, people's original woodgrain mysteriously was swapped for the reproduction type when giving this trim place their dash and console pieces to restore. Ask bullittljv8. No names on here please as to who it is. In fact you can walk into this place today with you HK glovebox woodgrain and they'll do it for you to match the rest. Exact same stuff. Same process. They are the ones bringing it in and they know how to adhere it to the metal pieces. Weird how it's not available in the rares kit but this mob can do it for you if you bring your glovebox piece in. If you found or made a better matched reproduction woodgrain then maybe you could strike a deal with them so they use it on theirs in return for knowing how it is applied.
Hmmm, just been advised that Rares have put in an order for the HK glovebox woodgrain from the above mentioned Adelaide supplier. A result of my older post above? Oh well at least if someone wants to go down that road they can get the full kit now. Edited by user Saturday, 31 December 2011 3:12:07 AM(UTC)
$110!! We were walking in there and getting them done for $65 last time I heard. Lol how they have the photo with the badge holes at the wrong end. |
put me down for a new set dave.also do you have a good long radio/heater for a hk gts? thanks luke
haha. how typical
regards DD
Davo
yes byron, im back from holidays now so contact me RE samples & will get onto it end jan & get something real happening
how did you go with the reproduction woodgrain for the hk interested as to how much and if you got a supply
dont worry about how much.if there the right ones it worth it.and knowing dave they wont cost the earth but will be priced accordingly.
yes definitely interested please let me know once they are happing
