Hi Guys
My 307 is running a bit rich at the momment. Its pretty much stock. What would the original jet size be or if anyone has got a recomendatation that would be great.
The jet size only really controls the air/fuel mixture at wide open throttle. If your engine is running rich you have a problem.
The most likely cause is float level (too high). Get a pro to check out the carby.
Dr Terry. |
thanks for the tip, sure it could do with a look at.
