What is the latest 202 cast date block seen or known of, before they were changed to a 3.3 cast on the block?
Good question. My 72 HQ ute (unsure if its the original) has 3.3 cast on the block.
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
202 runs up until HZ era from memory. I think I may have even seen a VB 3.3 with 202 on it. |
I believe the casting change was around mid 1979. Early VB had 202 cast blocks.
Dr Terry |
Hi my all original hz ute is 6/79 build has ZL eng no. & 3.3 cast block. Just out of interest when was the changeover to wb. Thanks Ron
Has anyone seen a 202 casting with a 1979 or later date code??
