#1 Posted : Monday, 7 June 2004 7:35:25 AM(UTC)
Hi guys.
Was after some advice on outting new bushes in the rear upper trailing arms on my HZ with WB stato disc end. Did lower arms today with no hassles, however have a few q's before doing the uppers. From what i have read, the leading bushes are pressed into the arm and the trailing one are pressed into a cradle on the axle. What is the best way to remove/install the trailing bushes? Special tools required or can something be made? Pressing the Leading ones in /out is no hassle but was a little worried about how to get to the trailing ones? Thanks for any help. tom
#2 Posted : Monday, 7 June 2004 9:32:10 PM(UTC)
When I had to replace the uppers in my HZ I spoke to our local Pedders franchise. They said even with the correct tools doing the bushes in the diff is a real pain of a job. The ones in the arms themselves are OK. It ended up being that the ones worn i
