#1 Posted : Sunday, 4 January 2004 6:55:00 AM(UTC)
Hi got a bizarre question for u ladies and gentlemen. my telstar over the last 3 days when I am driving has had noise like a creeking sort of sound coming from the left hand side then when I put the brakes on the sound changes to a rubbing tight sound,and some times i can feel it through the brake pedal, really hard to explain. I took the wheels off and the brakes have plenty of meat on them and seem to be ok. the sound comes and goes seems to do it more after I come out of a right hand turn and straighten up just want to save myself some money if one of u guys have had the same prob rather than put it into the brake shop
#2 Posted : Thursday, 8 January 2004 7:35:59 PM(UTC)
I would be pulling the left wheels off & inspecting your brake pads for wear & possibly a small rock stuck in them. Then check your wheel bearings for play/roughness to turn. Have you had new tyres fitted recently? as tread patterns can do this so
#3 Posted : Monday, 26 January 2004 1:10:35 AM(UTC)
Probably cvs. Put on full lock go around in circles slowly a couple of times, do this left then right, if it clicks when on left its the right one if on right its the left one.
Incidentally there was one of these went for $60 at the auto auctions the oth
