Hi everyone I'm looking for a Radiator to suit a ZD with a windsor, maybe a za zb or zc would work, email me at [email protected] please, thanks
Yep or an XW or XY 302 radiator will be the same part if you have a 302W powered Fairlane The XR/ZA 289 and XT/ZB 302 had the bottom hose on the wrong side from memory.
If you have a 351W then you will probably need an ZC, ZD, XW or XY 351 radiator which mounts at the top and bottom not the sides like the smaller radiators do. |
