#1 Posted : Thursday, 10 June 2004 4:21:35 AM(UTC)
does anybody know how to adjust the mixture on a 4bbl rocky on a blue v8
#2 Posted : Thursday, 10 June 2004 6:16:06 AM(UTC)
You can only ajust the choke or the secondary spring setting for the top butterflys. Which one are you refering to?
#3 Posted : Thursday, 10 June 2004 9:45:39 PM(UTC)
excuse my inexperience, im not sure but all i can tell u is that the vehicle is running very rich, like the auto choke is still on
#4 Posted : Thursday, 10 June 2004 11:23:26 PM(UTC)
Howdy,
If it has started running very rich without anybody playing around with the carby then open it up and check your float. The rochesters have a plastic (nitrophenyl) float that is notorious for filling up with fuel (absorbs it through the walls
#5 Posted : Monday, 14 June 2004 4:04:34 AM(UTC)
Hi Guys.
Yes, Paul E is correct, the most common cause of Q-Jets running too rich is the float. They seem to have a usable life of about 8 to 10 years.
You might as well overhaul your carby while you're replacing the float, you have partially
