ht307munro Offline
#1 Posted : Saturday, June 28, 2014 7:50:13 AM(UTC)
ht307munro
I am looking at refurbishing my quarter vent windows and see that the rubber for the Monaro is apparently different to the sedan/wagon/ute etc. I thought the actual quarter vent window was the same between all models (I understand the Monaro has the large chrome door pillar mould that the quarter window screws to) so what is the difference in the rubbers? Also how difficult is it to replace the rivets (which I guess is required to change the window rubber)? Thanks.
Alex
AMunro327 Offline
#2 Posted : Saturday, June 28, 2014 11:04:52 PM(UTC)
AMunro327
I'm not exactly sure and maybe one of the Rares guys will correct me if I'm wrong, but I think the difference is at the top of the metal spline that's embedded in the rubber.
On a Monaro, there's a screw that locates the top of the rubber to the chrome metal pillar that you spoke of. Sedans don't have that extra screw. The pic below shows the pop rivet that holds the top of the rubber to the frame and the hole at the top is where that screw goes.
I've done a few Monaro quarter rubbers over the years, so might put my two bob's worth in on how to do it or, more importantly, what traps there are in doing them
First you have to determine where the hinge support (the stainless bit that's riveted onto the frame) goes through the rubber and slit the rubber with a Stanley knife. They aren't slit in production.
Then, make sure the holes are in place where the pivot goes through the rubber and where the locating screw behind the pivot goes. Sometimes a thin layer of rubber covers these holes.
Next, apply a liberal coating of rubber grease to the outside of the new rubber, where it locates in the channels of the frame and insert the rubber. You'll probably find that you have to manoeuvre the rubber into its exact place, the rubber grease helps.
Before bending over the locating tabs in the metal spline, check to see if the top rivet hole lines up with the hole in the frame. I've usually had to file or drill out this hole because it doesn't line up.
I think the rest of the process you'll figure out while you're doing it.
I've tried a few different ways to swage over the hinge rivet. I've settled on doing it in a vice.
Place a ball bearing about 4mm diameter in the rivet opening and start doing up the vice. As the rivet starts to "belly out" remove the ball bearing and just use the vice jaws to squeeze it the rest of the way. You might need about 3 hands to hold everything in place while you're doing this.
ht307munro Offline
#3 Posted : Sunday, July 6, 2014 6:50:18 AM(UTC)
ht307munro
Thanks mate. The rubbers arrived on Friday, but now I think my Monaro quarter glass frames have been thrown out (they stainless section was rusted out) and I thought sedan ones were the same.
Alex
AMunro327 Offline
#4 Posted : Tuesday, July 8, 2014 2:44:07 AM(UTC)
AMunro327
If you're referring to the quarter window glass and the chrome plated metal frame that goes part way around it, there is no difference with a Monaro, they are all the same. The Frame that the quarter window assembly goes into (and forms the window channel) is different in Monaro to other models.
ht307munro Offline
#5 Posted : Sunday, July 13, 2014 2:03:17 AM(UTC)
ht307munro
Thanks mate. I was having a look today and have some passenger side Monaro ones (well I think I do) but no drivers side ones. In your picture you show a small rivet below the screw hole - did you drill that out (it looks like you have to so that the metal strip in the quarter glass rubber can go in there)? If so what did you replace it with? I standard rivet protrudes quite a bit. Also with the pivot rivets (supplied by Rare Spares) there is some washer in the kit - where do they go? Cheers.
Alex
AMunro327 Offline
#6 Posted : Sunday, July 13, 2014 2:43:45 AM(UTC)
AMunro327
Yep, I drilled out that rivet and just used a short rivet when replacing the rubber.
I assume that the washer goes onto the pivot rivet before you start to peen the rivet over. I didn't bother using that washer.
ht307munro Offline
#7 Posted : Sunday, July 13, 2014 3:14:34 AM(UTC)
ht307munro
Thanks heaps mate. Now to give it a go.
Alex
This page was generated in 0.065 seconds.
