#1 Posted : Friday, 18 June 2004 6:43:17 AM(UTC)
hi ive put a hr disc brake front end on my eh and was wondering has anyone done this and not used a brake booster?
#2 Posted : Friday, 18 June 2004 5:29:07 PM(UTC)
I tried my hk without a booster. Not good. The EH is lighter, but I believe the pedal effort will be very high
#3 Posted : Friday, 18 June 2004 7:24:26 PM(UTC)
I had a HR with discs and the previous owner had run it by bypassing the booster (as it was clagged), the pedal was very heavy and I don't think it was safe to drive for any length of time!! I remember that when the booster was fixed I nearly threw mysel
#4 Posted : Monday, 21 June 2004 7:36:11 AM(UTC)
You will find you are mainly working the rear drum brakes so all the effort goes there, they wear quick and fade quick, and lock up all the time, and the braking effect is greatly reduced as the front brakes are not getting enough pressure. You will have
