Hello Gents, are coupe fuel tanks the same as sedan? Wagon? Are XA, XB & XC all the same?
Later XB's and all XC's will have more connection points for the evap emission gear which is no problem when putting a later tank into an earlier car as you can just block them off.
I did hear once that sedan and hardtops have the same tank but I'm not 100% sure on that. Someone else will be able to clarify.
I can clarify. Coupes are the same as sedans, fairlanes and LTDs.
Oh one thing. The filler pipe that goes into the tank is coupe only.
