coupe Offline
#1 Posted : Wednesday, 24 June 2015 10:35:04 PM(UTC)
coupe
Hi guys looking for a 10 bolt diff to powerglide tailshaft as stated. 1362mm uni centre to centre apparently, cheers
#2 Posted : Wednesday, 24 June 2015 11:39:51 PM(UTC)
Was thanked: 487 time(s) in 464 post(s)
FYI I think this is the same as an original GTS327 and a 307 manual tailshaft, dark green. Will edit if my memory has failed me!
gm5735 Offline
#3 Posted : Thursday, 25 June 2015 9:35:24 AM(UTC)
gm5735
Correct as expected Byron.
The dimensions below for length are the uni centre to centre distances, and are different from your 1362mm.
For HK, The service manual and parts manual call for Dark Green, 1364.2 - 1365.8mm/53.71-53.77" length, 69.85mm/2.75" diameter, 1.65mm /.065" wall thickness. Part number is 7439318
For HT, The service manual defines the tailshaft for 307 and 308 Auto Salisbury as Light Bronze Green, 1382.3 - 1383.8/ 54.42 - 54.48", 69.85mm/2.75" diameter, 1.65mm /.065" wall thickness. Part number is 2806833
The HT parts manual, however, still lists the dark green shaft for 307 Auto/Salisbury, and the light bronze green shaft for the 308 Auto only.
#4 Posted : Thursday, 25 June 2015 4:53:11 PM(UTC)
I'm almost certain that HT service manual is incorrect. For HQ the Chev engine is moved forward so its rear sits level with where a 253/308 sits (Chev is about 3/4" longer). For HT-HG they don't and the Chev rear is further back than the 253/308 thus the gearbox moves back as well hence the shorter tailshaft for the Chev engine.
coupe Offline
#5 Posted : Thursday, 25 June 2015 6:37:53 PM(UTC)
coupe
Thanks for the info guys does anyone have one they want to sell?
#6 Posted : Thursday, 25 June 2015 9:39:28 PM(UTC)
I have 3 of them but I also have 2 x GTS327's and 2 x 307 GTS's so only just have enough (one GTS has a pink tailshaft as it is a banjo).
hk350 Offline
#7 Posted : Friday, 26 June 2015 9:21:17 AM(UTC)
hk350
Do you have a pic of the pink tailshaft HK1837? That's what mine should have and need to know which shade of pink it is. Thanks.
#8 Posted : Friday, 26 June 2015 5:06:12 PM(UTC)
It is in the car 300kM away. I will be able to though next time i'm near it. It is the same tailshaft as a HT-HG 253 M21, this one came from a HG V8 Kingswood sedan with optional M21 that I rescued from demolition derby duty.
This page was generated in 0.184 seconds.
