#1 Posted : Wednesday, February 18, 2004 3:46:09 AM(UTC)
is there any trick to changing axles?do i have to line them up,or do they just slide in and all is cool?
#2 Posted : Wednesday, February 18, 2004 6:22:38 AM(UTC)
What are they on? I have only ever worked on Fords with dick brake rear end. You have to make sure you turn the disk around and take off all the 4 nuts or you will pull the bearing apart. Use a wheel like a slide hammer to pull the axle out. Put the nuts
#3 Posted : Wednesday, February 18, 2004 7:56:06 AM(UTC)
bill its a drum brake xd.what do you mean i have to line the splines up?will it destroy itself if i dont line the splines up?
#4 Posted : Wednesday, February 18, 2004 7:56:22 AM(UTC)
#5 Posted : Wednesday, February 18, 2004 8:25:23 AM(UTC)
it's very easy to change axles,
after undoing the retaining bolts that hold the wheel bearing on the end of the diff housing where your brake drums are the axle should slide out, if it is stuck on put the wheel back on the studs but only put the wheel nu
