#1 Posted : Friday, 11 June 2004 6:03:22 AM(UTC)
Hi, I've got an XF 250X-flo in an XB ute, extractors and an exaust and cold air intake, I have bought a 350 holley, and was wondering what jet size to use, it came off a 202 holden red motor so maybe a size up, but I dont know what size is in it. I only want the 350 instead of the weber because I can richen the mixture, for the extra oxygen from the cold air intake. Plan to add a cam at a later date too.
#2 Posted : Friday, 11 June 2004 6:37:58 AM(UTC)
just put it on and go from there,if you want to keep your cold air induction,get a 4 barrel air cleaner of an xc v8 etc and hook it up.i have this and it works a treat.
#3 Posted : Friday, 11 June 2004 7:41:24 AM(UTC)
Cheers for the info, the only thing, will a standard 2bbl air cleaner off an XA fairlane fit the holley. I think the standard carb is an autolite or a carter, not entirely sure.
#4 Posted : Friday, 11 June 2004 6:24:59 PM(UTC)
no you need the 4 barrel air cleaner,they are the same size hole as the holley.
