#1 Posted : Wednesday, 23 June 2004 4:59:54 AM(UTC)
Hi,just wondering if anyone can explain how to go about adjusting the kickdown on a tri matic as i have to drop down to second manually at the moment,ie,,put the selector in to second,its a pain in the ass.
#2 Posted : Wednesday, 23 June 2004 5:47:58 AM(UTC)
trimatic has two things to kick them back,the first is manual hooked up to the throttle inside and the second manifold vacume probable your problem.
make sure the steel pipe running down to transmission from the inlet manifold is attached both ends and
