#1 Posted : Sunday, May 9, 2004 6:13:52 PM(UTC)
Hi Bruce. Have no email at home so I thought I would post here. Just wanted to confirm a few things. Have the money order. Had a look yesterday at removing sunroof. Removed the roof lining and found that the whole thing is one large unit. It is 1030cm x 1010cm with the motor and everthing encased inside it. It has 4 brackets towards the rear wich are riveted to the side braces in the roof and apppears to be glued to the roof. I think instead of cutting the roof I just need to drill the rivets out and then the whole thing should come away from the roof. This will make it easier for you to fit as well I think. Can you let me know what you think. Do you still need the roof cut. I think it would be easier to just remove the unit.
#2 Posted : Monday, May 10, 2004 3:44:32 PM(UTC)
Hi Glenn.
Just remove the rivets/screws. No need to cut the roof if it is not necessary.
Is it possible to photograph the sunroof from inside the car before you remove it, so I can see how it was originally fitted?
Bruce
