#1 Posted : Wednesday, 2 June 2004 2:44:20 AM(UTC)
My WB ute has a problem where the timing keeps changing. I have changed dizzy, carby(the prev. carby was only being fastened down in 3 spots) and new points plugs and condenser. Someone removed Elec. Ign. before I picked it up.
When its running rough it PUMPS out unburnt fuel and some burnt oil,ie black and blue smoke, embarrassing.
#2 Posted : Wednesday, 2 June 2004 2:55:11 AM(UTC)
Could be your harmonic balancer slipping. It is a common fault on older engines.
#3 Posted : Wednesday, 2 June 2004 5:18:07 AM(UTC)
cheers i'll check that, makes sense. cause i set the timing and i can watch it jump 1-2 degrees both ways. thanks steve.
#4 Posted : Wednesday, 2 June 2004 4:29:45 PM(UTC)
If it's a V8, it might be that the cam timing chain has reached the end of its useful life.
#5 Posted : Wednesday, 2 June 2004 8:11:31 PM(UTC)
Its a 202. Found a vacuum leak in the intake manifold last night. gonna change that this weekend, or earlier if i can.
#6 Posted : Friday, 4 June 2004 7:50:34 PM(UTC)
A good check for the harmonic balancer slipping is to get the engine warm and move the dizzy each way by hand until the motor is idling the best. Tighten the dizzy down and then put the light on the balancer and see where the mark is. Take the car for a
#7 Posted : Saturday, 5 June 2004 6:58:40 AM(UTC)
My 202 balancer came so loose it wore a groove in the timing cover, i thought the noise was the water pump or alternator, replaced them both before I realised.
#8 Posted : Saturday, 5 June 2004 5:11:42 PM(UTC)
The harmonic balancer came loose on my 202 also.....and hit the roof of the car travelling behind me!
The poor driver thought he had been hit by space junk!
Who was I to tell him different?
My only problem was I was going nowhere until I extracted the
#9 Posted : Saturday, 12 June 2004 6:23:30 AM(UTC)
my old HQ used to do the same thing the all of a sudden the thing would not start check the fibrus cog at the bottom of the dizzy if you can replace it with a steel one mine broke a tooth then shit itself and fell into the sump. endid up replacing dizzy w
