Can anyone tell me if I need to modify the transmission hump or any other body mods to put a 253 and 4 m20/21 into a HQ sedan that currently has a red 6 and crash box behind it
no need to modify the floor , only where you are putting a shifter in. everything should just bolt up.
You will need to fit another rear hanger mount for the exhaust system if you are going run twin exhausts. otherwise as cloudy says, only other mod is for a floor shifter, if needed... Kevin
