#1 Posted : Tuesday, 22 June 2004 3:02:11 AM(UTC)
hi again fellow enthusiasts.
I have a HZ V8 that, when at about 110kph, the needle starts to bounce. Can this be an easy fix if i pull it down or should I just go and get another one?? I would like to keep the original if possible.
Thanks;
Geoff
#2 Posted : Tuesday, 22 June 2004 5:23:43 AM(UTC)
It is most likely that the nylon gear in your gearbox is worn . You will have to remove the extension housing to replace it .
Shawn
#3 Posted : Wednesday, 23 June 2004 12:45:12 AM(UTC)
The peedo head has come too close to the magnet, will need recalibrating by an instrument fitter.
Warren
#4 Posted : Wednesday, 23 June 2004 5:33:08 PM(UTC)
RECENTLY HAD THE SAME PROB,WAS THE JEWEL THAT THE NEEDLE FITS IN. COST ME $85.
#5 Posted : Tuesday, 6 July 2004 12:21:14 PM(UTC)
IN MY PAST 59 YEARS OF EXPERIENCE IV ALWAYS FOUND THAT IS CAUZED BY A STRETCHED SPEEDO CABLE, AND IF ITS STILL GOT THE AUSSIE MANUAL OR AUTO BOX, NO U DONT HAVE TO REMOVE THE EXTENSION HOUSING. EITHER A 3/8 OR A 7/16 SPANNER TO REMOVE THE RETAINING PLATE!
