#1 Posted : Wednesday, 11 August 2004 7:51:27 AM(UTC)
I have posted this on the ls1 forum with no reply so I thought I might post it here.
Recently, my new van (UWC) has developed a scraping noise in the front end when the car has been driven around for awhile. The car has been lowered 2" and done only 4000 kms.
At first, I thought it was Holden's fault due to the fact that it happened after I got the power steering lines replaced by them, but when I took it back to them they blamed my lowered suspension.
So, I thought I would take it Pedders to get an independent assessment done apart from where I got the lowered suspension installed. A few bolts needed retorquing but thats all.
Pedders recommended that I remove the mudflats but it happens apart from when I bottom out.
I think the discs are warped or maybe the pads are not retracting when the car has been driven.
If it is brakes, and I get Holden to repair them, is this common in new Commodores?
Could it be the tierods? I dont know.
The sound only happens when I turn corners and come to a stop. I think its the power steering but Holden has already looked at this.
I might take it to another dealer and get a second opinion.
I dont know what to do.
#2 Posted : Thursday, 12 August 2004 12:06:44 AM(UTC)
I've had 2 VT's over the years, and both of them did it as standard. Sounds like as you say the discs are warped, or the pads aren't fully disengaging. You could only hear it at low speed.
The reason I read somewhere, had something to do with the an
#3 Posted : Thursday, 12 August 2004 4:22:32 AM(UTC)
Hi Sean
I'm pretty sure I know what it is & I haven't been for a run in your new VY van yet, drop around to the workshop & I'll have a listen.
