#1 Posted : Wednesday, 8 September 2004 3:13:25 AM(UTC)
Just wondering what is required regarding engine balancing/blueprinting ? Should these be done at the time of reconditioning an engine, or can it be done post reco?
Also, what are the advantages of having a new engine balanced and blueprinted ?
Cheers.
#2 Posted : Wednesday, 8 September 2004 4:22:55 AM(UTC)
well balancing is usually done at time of reco as the engine needs to be in bits.
You can do it afterwards but i dont really think its worth stripping the engine apart just to have it balanced.
Blueprinting is reco'ing it and bringing it all back to it
#3 Posted : Wednesday, 8 September 2004 8:42:44 AM(UTC)
Blueprinting is a bit more than just reconditioning. The average reco allows for certain clearances from specification, for instance the specification for a bearing journal might be 50mm, with a + or - .25mm, so each of the set of journals can be 49.75 to
#4 Posted : Wednesday, 8 September 2004 6:18:02 PM(UTC)
The other side to this can explain why some engines lasted poorly from factory, and others last exceptionally. If your engine just happened to have most measurements very close to the exact spec, (as John mentions), chances are it will run very well and
#5 Posted : Saturday, 11 September 2004 6:21:47 PM(UTC)
Johnperth is right.
Many people wrongly use the term blueprinting or are misled by their enginebuilders and are just buying rebuilt engines.
Blueprinting is extremely expensive and beyond the price of most people. Very few people would have
#6 Posted : Tuesday, 2 November 2004 10:46:07 PM(UTC)
