peterwmh Offline
#1 Posted : Wednesday, 23 January 2008 9:29:12 PM(UTC)
peterwmh
Hi all,
I have a 14x8 Chevoit 'hotwire' mag that I think is from a HQ-WB Holden but I'm not 100% sure. Just wondering is the PCD the distance between centres of the opposing holes in the 5 stud pattern? If so what was the PCD for all Holden stud patterns so I can confirm what I have? Would you have the Ford PCD also, just in case I have slipped up and have a Ford part in my shed!!
I want to sell the wheel but want to be sure of what it suits!!
Peter
#2 Posted : Wednesday, 23 January 2008 9:42:36 PM(UTC)
Was thanked: 211 time(s) in 192 post(s)
Hi peter.
FE-HR Holden & most Torana's PCD is 4.24". HQ-WB is 4.75". Ford is 4.50". Commodore is 120 mm.
#3 Posted : Wednesday, 23 January 2008 9:42:36 PM(UTC)
Hi peter.
FE-HR Holden & most Toranas PCD is 4.24". HQ-WB is 4.75". Ford is 4.50". Commodore is 120 mm.
bundybluedog Offline
#4 Posted : Wednesday, 23 January 2008 10:10:16 PM(UTC)
bundybluedog
PCD means Pitch Circle Diameter and is measured from the centre of one hole to the centre of the oposite hole. on a 5 stud paturn you should measure from the centre of one of the stud holes to the centre of your mag the multiply by 2, to give our PCD. if
#5 Posted : Wednesday, 23 January 2008 10:11:01 PM(UTC)
Was thanked: 530 time(s) in 506 post(s)
There are no "opposing holes in a 5 stud pattern. Only in 4 and 6 stud. You need to draw a circle through the centre of the holes and measure its diameter. Most Chevoit hotwires should have 4.25, 4.5 or 4.75 stamped on the inner face of the wheel where it
#6 Posted : Wednesday, 23 January 2008 10:11:01 PM(UTC)
There are no "opposing holes in a 5 stud pattern. Only in 4 and 6 stud. You need to draw a circle through the centre of the holes and measure it's diameter. Most Chevoit hotwires should have 4.25, 4.5 or 4.75 stamped on the inner face of the wheel where i
#7 Posted : Wednesday, 23 January 2008 10:13:26 PM(UTC)
bundybluedog
a 5 hole paternt is not opposite on a PCD were a 4 or 6 hole paturn is as long as its equaly spaced
JBM Offline
#8 Posted : Wednesday, 23 January 2008 10:22:17 PM(UTC)
JBM
This might help, its the 120 PCD for a Commodore and the HQ is only slightly different.
James
You only have to be in front
peterwmh Offline
#9 Posted : Wednesday, 23 January 2008 11:11:39 PM(UTC)
peterwmh
Thanks to all, that's very helpful.
Peter
peterwmh Offline
#10 Posted : Wednesday, 23 January 2008 11:11:39 PM(UTC)
peterwmh
Thanks to all, thats very helpful.
Peter
202 and three on the tree, cant get more Aussie than that!!
peterwmh Offline
#11 Posted : Wednesday, 23 January 2008 11:22:40 PM(UTC)
peterwmh
Bugger it's a 4.50 inch PCD, so it's from a FORD...arrgghhhh!! Oh well might Ebay it and see how I go!!
Peter
peterwmh Offline
#12 Posted : Wednesday, 23 January 2008 11:22:40 PM(UTC)
peterwmh
Bugger its a 4.50 inch PCD, so its from a FORD...arrgghhhh!! Oh well might Ebay it and see how I go!!
Peter
peterwmh Offline
#13 Posted : Thursday, 24 January 2008 8:01:21 PM(UTC)
peterwmh
Ive been asked a question on Ebay, is the wheel a 5 x 108, would that mean 5 stud and 108mm between the two wheel studs as shown in the diagram in JBMs reply?
Peter
peterwmh Offline
#14 Posted : Thursday, 24 January 2008 8:01:21 PM(UTC)
peterwmh
I've been asked a question on Ebay, is the wheel a 5 x 108, would that mean 5 stud and 108mm between the two wheel studs as shown in the diagram in JBMs reply?
Peter
#15 Posted : Thursday, 24 January 2008 10:06:17 PM(UTC)
Hi Peter.
Torana & FE-HR Holden PCD is 4.24" which 107.7 mm. This often often rounded-off to 108 mm.
JBM Offline
#16 Posted : Thursday, 24 January 2008 10:15:52 PM(UTC)
JBM
JBM Offline
#17 Posted : Thursday, 24 January 2008 10:15:52 PM(UTC)
JBM
peterwmh Offline
#18 Posted : Thursday, 24 January 2008 10:21:24 PM(UTC)
peterwmh
Thanks guys, looks like the guy asking the question wants to know if it's an early Holden/Torana wheel, and it isn't. Thanks again!
Peter
peterwmh Offline
#19 Posted : Thursday, 24 January 2008 10:21:24 PM(UTC)
peterwmh
Thanks guys, looks like the guy asking the question wants to know if its an early Holden/Torana wheel, and it isnt. Thanks again!
Peter
adam PERTH Offline
#20 Posted : Tuesday, 12 February 2008 4:23:12 AM(UTC)
adam PERTH
peter.
i have a few single 14 x8 hotwires.
one for FOrd , one for Torana, one for HQ
how much did you want for your ford one?
A1 Bogan.
