#1 Posted : Tuesday, 27 July 2004 2:05:33 AM(UTC)
have small prob with car, it wont start, it started yesturday after i changed the oil n stuff, and it ran fine. today when i go to move it, i tried to start it and it wouldnt do anything. the speedo swung from 0 to about 80 while i was tryna start it too.
Car is 3spd auto, 4.1L efi.
im thinkingits the battery and the starter motor that has gone-which is easy fix, but i am unsure as to why the speedo would move when im starting it...?
any ideas?
thx in advance
#2 Posted : Wednesday, 28 July 2004 9:48:20 AM(UTC)
what model is your car?
#3 Posted : Wednesday, 28 July 2004 11:58:03 PM(UTC)
ZK Fairlane
#4 Posted : Friday, 30 July 2004 7:44:16 AM(UTC)
What's the earth lead on your motor like?
#5 Posted : Friday, 30 July 2004 7:44:32 AM(UTC)
#6 Posted : Friday, 30 July 2004 8:05:37 PM(UTC)
Thats the big wire that runs from the front of the head to the battery right...?
#7 Posted : Friday, 30 July 2004 8:37:11 PM(UTC)
Yep its fine, it hasnt come off either the head or the battery, n there is no corrosion around the terminal on the battery either.....
#8 Posted : Friday, 30 July 2004 10:45:43 PM(UTC)
Assuming that you have already checked the basic stuff like fuses and fusible links. Put a multimeter on the starter and see if it is getting any current. Trying a different battery might not be a bad idea in case youve dropped a cell, you can still have
#9 Posted : Friday, 30 July 2004 10:46:00 PM(UTC)
#10 Posted : Monday, 2 August 2004 12:19:09 AM(UTC)
i got the car to start, battery is screwed-its happily bubbling away as the motor runs...
when i started it, it didnt try to swing the speedo around to 80+kphr, which i thought was werid. still it started so i am happy about that.
#11 Posted : Thursday, 5 August 2004 4:01:21 AM(UTC)
always check the termails on the baoy of the car and engine this can couse major computer problems also
