Hi there another Question for you all. HZ one tonner changing the dash and using after market Speedo. Do i need to change cable or is there a brand with a speedo that will fit straight in? Any suggestions or tips on any dash work would be appreciated too
Check all that out "before" you buy one,usually depends on the gauge and gearbox/trans combo,the maker should have all that info.
Jim in Adelaide.. |
Jim in Adelaide.. |
