Why is the spark jumping from the plug cap to the coil on a V6? It still arks across the coil to where the lead plugs on even when the lead is pulled off. Its our excellent circle work car and is rubbish when it is only running on 5.
Electricity finds the easiest ,shortest path.(something is cracked letting the spark escape)
Jim in Adelaide.. |
Jim in Adelaide.. |
Measure the HT leads with a multimeter. My bet is that the no. 5 lead is open circuit.
Dr Terry.
When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
Thanks for the replies. Will have a go at testing the leads when I get a chance.
