Hi everyone. Hope so far the new year has been good to all and will get better for flood victims.
My HQ currently doesnt have air con and am thinking about putting one in one day. Whats the best way to do this. Find a unit from an old HQ and put that in (are they hard to find fully recond..??) or are there any after market units that are good and where to get these from.
Any advise would be great.
Thanks Michael.
I fit a/cond for a living & some stuff is getting hard to find. Most companies that manufacture a/cond no longer exist because virtually all new cars get a/c as standard equipment. The most difficult bits to get nowadays are the mount & drive kits. That means all the brackets, spacers, bolts, nuts, pulleys & belt etc. that mount the compressor to that particular motor. New compressors, condensers, evaporators, driers, hoses etc. are all easily available, I stock heaps of them. The neatest & most efficient a/c system for an HQ, would be to fit a new modern underdash evaporator unit in place of the glovebox lid. Get a new Sanden style compressor & a new condenser then make custom hoses to suit. Find a 2nd hand mount kit off any VB-VH 6-cyl Commodore or HX/HZ/WB with Air International accessory a/cond (these original have Sanden SD508 compressors fitted) (I assume you HQ is a 6-cyl). Keep the factory 4-blade fan & add a 12-inch condenser fan wired thru a relay. Dr Terry _________________________________________ When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. Edited by user Thursday, 20 January 2011 9:51:21 AM(UTC)
| Reason: Not specified |
Thanks Dr Terry.
My car is a GTS sedan with a 253. If i was to put an after market one in, would it look funny or can you get something that looks pretty resonable and would go with the black interior. Are there any companies i can search to see what products they have.
Roughly how much would it be for someone to do all the work and install an air con into the HQ.
OK, the only difference here will be obtaining a complete mount/drive kit from an HQ-WB 253/308 V8 to fit a normal Sanden style compressor. None of the Commodore kits will go close.
The dash unit that I use in HQs is from the era, with a black & chrome front panel. It suits 70s cars very well.
It is a costly install, parts & labour will set you back around $1800 incl. GST. This is using all new parts (except for the mount kit) & would come with 12 months warranty.
When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
Dr Terry do you know anyone closer to Melbs who does the same thing? I would not rule out going for the drive though...
Is this the same compressor that a 308 HJ Statesman would have? If so what are they worth, and I assume that the dryer needs to be updated from the original to suit the newer (R134?) gas?
I'm sure that there would be a few 'older' a/cond installers in Melbourne who would know their way around an HQ. Try the Yellow Pages under 'Air Conditioning - Automotive' & ask a few of the companies listed. Dr Terry _________________________________________ When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
No. That's why I referred to it a 'Air International Accessory A/Cond'. These units use the Japanese Sankyo (now Sanden) SD508 which was probably the most widely used aftermarket compressor. The factory fitted system in HQ to WB use the GM A6 compressor. This is the bulky black unit often labelled as Frigidaire or Harrison. Dr Terry _________________________________________ When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
Hi Dr Terry I have a HZ caprice with factory air cond which I would like to get working again, everything is as it left the factory at the moment. what would you recommend I do ie replace compressor with sanden keep original compressor and replace hoses your ideas would be appreciated thanks Brian
I wouldn't recommend replacing the GM compressor with another type, the money time & effort is not worth the outcome. While the Sanden compressor maybe smaller, lighter & use less power, the main reason for this is that they have less pumping capacity & therefore less output. The GM compressor displaces 12 cubic inch while the Sanden displaces just 8 ci, that must say something. It is better to just repair, place or refurbish the original parts on the vehicle. I doubt that all of the hoses need replacement. The most common repair on these systems is a compressor reseal. Dr Terry _________________________________________ When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. Edited by user Monday, 24 January 2011 4:21:46 AM(UTC)
thanks for the reply Dr T I didnt think the old compressors would still be repairable these days, I thought that I may have to fit a newer one, glad I dont have to as the capacity of the new ones is a concern for me. with regard to hoses, I was told that I would need to replace these as the new gas is to high in pressure, fact or fiction?
thanks Brian
thanks Brian
The high pressure side of the system is marginally higher on hot days in traffic, but the hoses are designed for pressures much higher than that. The main reason you hear that hoses need to be changed is that the older type hose is supposedly more porous to the newer R134a gas than it was to R12. R134a has now been around for over 18 years & I've yet to see any evidence of this 'porosity'. I've converted 1000s of cars from R12 to R134 with no issues at all in this area. I think it's a bit like man-made climate change, once one 'scientist' puts forward a theory in print. it is then taken as gospel, without any serious discussion. Dr Terry. _________________________________________ When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. Edited by user Monday, 24 January 2011 6:21:24 PM(UTC)
Thanks Dr T for your advice also apologies to Michael_4 if I have hijacked his thread
LOL thats no problems. The more information the better.
We are lucky Dr Terry is willing to share his knowledge.
I did the conversion on my HQ tonner. Bought a HZ with air and took all the bits off that. everything bolts straight in excepting the behind dash ducting is different because of the shape of the dash you must get the Q ducting, also the Q dash has an extra vent in the centre, and the fan switch is a bit larger than the Q one so you have to file out the hole in the dash slightly. doing it this way you get a conversion that is not intrusive or noticeable. I also used a compressor off a VH and the mounting kit that came with that.
forgot t...the reason I used the VH compressor was I was running gas and the original compressor was too large and did not leave room for the gas setup.
Hey Dr Terry, Just wondering if you would be able to give me any info on anyone in the sydney area that could install air-con in my 79 Kingswood HZ. Would be greatly appreciative for any info from anyone else either that could help me out. Thanks Megs
Thanks: 1 times Was thanked: 35 time(s) in 33 post(s)
Dr Terry is in the Sydney region, and his workshop is perfect for your needs. Give him a call on 9644 2888
Thanks heaps for that mick will give him a call now.
Dr Terry, can you rebuild Harrison Compressors? Is it cost effective or is a new one the only way to go?
