Hi just wondering is the power steering setup for a Brougham 308 be the same as one for a HG 350 Monaro, I understand that the pulleys may be different but was more thinking the steering arms ram etc would they be all the same size and length. Would there wheel base/width be the same. Thanks in advance for any help. |
If you see rubbish put a circle around it.(FORD) |
Holden engine setups are the same (obviously differ at engine between 6 and V8). The Chev units have a different bracket that attaches the ram to the rails. That bracket is the impossible bit to find. Most people don't bother anymore, and fit a power rack. |
Call Roger on 9758 1965 , he will be able to help you with genuine power steer on your HK HT HG
Joined: 16/09/2010(UTC) Posts: 410 Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
Not only is the bracket for the ram to subframe different but also te drag link for Chev engined models. Best to get a set up from an HK Brougham. |
The HKTG Garage. The Home of HK HT HG Holden. |
Thanks for the help fellas will give Roger a bell. |
