Broke my right side axle on my chev 10 bolt diff, chasing a new/old stock as cant find any. Any help or info would b great as dont want a costly change over..... |
Take it easy, drink Bundy |
Talk to Moser, you might be able to get a new one made relatively cheaply. |
Spot on. This is about your only option now, unless you want to risk a dodgy secondhand axle that is over 40 years old and you do not know the history.
See your local speed shop, they will be able to recommend a couple of places in the USA that will make up brand new axles. Had a mate do this recently when he broke one. He went with Moslers, They were around $700 a pair with a lifetime warranty.
G'day mate, Had the same thing happen a couple of years ago and replaced them both with Moser axles. Barry from Tans Diff in Boronia(?) organised all that for me. Don't know if he is still there. Cheers Al
mate i bought a set of moser axles from supatrick in melbourne for mine.. easy as.. I have also heard u can use late commodore axles but cut 10,mm off the end of each..dont quote this as true though
