Fastlane
Holden Forums
Holden Technical Talk
Mounting Front Seatbelts in EJ Wagon
Hi guys,
I'm trying to track down instructions on how/where to fit the pillar bolt (in between front & rear doors)for a Lap sash seatbelt on my EJ Wagon.
Floors fine as they came with mount points, just not on the pillar.
Can anyone point me in the right direction?
Thanks. Joel
Joined: 2/02/2009(UTC) Posts: 562 Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 30 times Was thanked: 8 time(s) in 8 post(s)
I suggest contacting an EJ/EH club, bound to be a car there that you can get measurements from. Since the bolts were right through the B pillar, you may have a bit of latitude to go for a higher mount if you're a tall fella, or lower if you're like me. |
Attn camry drivers. The accelerator is the skinny pedal on the right. |
www.ehholden.com.auEH Club Vic Website has a tech article on fitting front seat belts. |
Fastlane
Holden Forums
