Can someone advise me of how to find out the build date, and any other releted info on a ht/hg Monaro? thanks.
As you look at it there will be a date code stamped on the bottom left of the steering box (assuming it's the original box), and if it's still there you will find a stencilled date code on the end of the steering column poking out of the firewall into the engine bay.
The date code on the box is day month & year, eg 12D9 means 12/4/69, you will have to check the archives to get all the codes. That date will be the day or very close to the assembly date.
Thanks, I found "3J9" So I'm guessing 3rd. October 1969?
if it closely matches th date on ya big nut m/cyl & left front side of outrigger, ya pritty original regards DD www.bellarineclassicautos.com.au
There was no letter I used so 3J9 would be 3rd sept 69 (I might be wrong)
Well the master cylinder has no big nut, just a cast housing. It's been that way since the early seventies. The front-end/outrigger has just been painted, so I've lost that info. cheers.
