Thanks: 6 times Was thanked: 2 time(s) in 1 post(s)
I'm chasing the 3 speed auto shifter Thanks
Thanks: 1 times Was thanked: 607 time(s) in 574 post(s)
Not just Monaro got a trimatic, you'll find them in Premier, Brougham, Belmont, Kingswood and GTS. Pretty rare outside of GTS though and never in GTS350. You can modify a Powerglide one - there is a guy that sells the piece with the detents on it on Ebay to suit Trimatic which will also suit TH350. Just the console insert reads wrong. If you ever find two console inserts let me know, I'm probably going to put a TH350 into the yellow 307 auto car initially at least and I only have a Powerglide console insert. |
Yeah I've got th350+307 I will probably just put a b&m in there There's a commodore shifter in there at the moment,maybe I just need the Monaro shifter handle Looks like that other HK Bathurst Monaro sold that was on trademe , that one had 150k on it
Monaro stocks are high!
I have heard a Cortina one fits in the hole where a manual HK-HG console insert goes. |
Sacrilege ! Looks like I will mount a b&m under the factory consol Someone must have done that before Ah hk1837 - do you know what the casting number on the heads for the gts327 were ?did the Monaros ever get 461 or 462 heads?what about the 350ht? Must be some good heads to be pumping out 300hp Cheers
HK Tonawanda engines were the same design heads as the 307, just Tonawanda's version of them. 1.72/1.5 valves, small ports and 69cc chambers. 3917290 casting. The McKinnon GTS327 engines were 75cc chambers, same valves and ports, 3927188.
GTS350 manuals used Fuelie heads, they weren't double hump as Tonawanda didn't use the double hump mark, 3947041. The last of the HG engines from McKinnon used double hump heads, 3973370, these were bigger intake port heads.
GTS350 autos used a 75cc head, same bottom end as the manual engine just the larger chamber heads, 3932441. |
Joined: 16/04/2014(UTC) Posts: 768  Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
Byron, I believe you'll find the bottom end on the GTS350 auto engines are 2 bolt main bearings, vs the GTS350 manuals 4 bolt.
They are but that doesn't affect the performance, just the durability. Same pistons and camshaft, only variable between the LM1 and L48 as we got them respectively for HT-HG GTS350 auto and manual was the heads and the initial dizzy timing specified. |
