Joined: 22/08/2016(UTC) Posts: 1 ![Australia Australia]() Location: Clayton South
Hi guys.
Looking to either rebuild my diff or just get a new 9" set up with disk brakes..
Does anyone know what the standard setup.is in a zc fairlane 302???
Is it best to rebuild this and upgrade to disk??
Any help.would be awesome
Dan
Thanks: 13 times Was thanked: 22 time(s) in 20 post(s)
I would just do the old B/W up or maybe look for a XG or XH the p van diff to put under it, most are 3.27 ratio.
Standard diff would be a B/W 2.92 in a 302 ZC with a 302w.
I don't think you can just put the disc axles in your diff ZC housing due to the bearings are different and other things.
Thanks: 1 times Was thanked: 242 time(s) in 233 post(s)
Even a 1993-ish XF ute diff. I bought one a while back for $100 just for the brake backing plates. It is an LSD 2.92 from memory, car was a carby 4.1 with T5 box. 1993 from memory. |
