Originally Posted by: abi Whats really upsetting about this Decision by GM back in the day, the only difference in the 250 and 275HP engines were 2 part numbers, the 1.94 intake valves vs the 1.72 inch we got and the bare head castings. Both of these items added zero cost to production so would have resulted in cost to Holden the same as the engines we ultimately received.
I guess from history we know the GTS 327 was never challenged in a straight line by the XT GT so in the end the choice by Holden was a good one. This was not the case for the next model HT 350, that 300HP 350 was absolutely no match to the Windsor HO 69 XW, a real pity.
ABI
Remember though that whilst John Bagshaw wanted the 327 for the HK, the car was never intended to race at Bathurst. The intention was for Group C (Improved Production), and this is why GMH started the association with Norm Beechey using the first of their factory racers, the EH S4. For Improved Production you only needed the 327's capacity and could use any hi-po 327 from the US parts bin. The stock 4BBL 327 with hydraulic lifters was chosen, back at planning stage it was 230hp. The decision to race the car at Bathurst and in selected Series Production races only came about after Ford (after hearing about GMH's upcoming special car) produced the XR GT and won the Gallagher 500 in 1967. GMH changed the suspension on the GTS327 early in 1968 so that it could be competitive.
There would have been a cost to run the 275hp 327. For the HK GTS327 GMH used
exactly the transmission and rear axle that GM used for that L48 250hp engine in the same sized car, the Saginaw and the 10-bolt. In a Camaro the 275hp engine triggered a heavier duty Saginaw (same as the GTS350 got) and a 12 bolt, both added cost. The optional 12-bolt for a HK GTS327 cost over 10% of the car's purchase price at the time, although in production this would have been less. GMH took some poetic licence with the HT GTS350 manual as by rights that engine should have got a Muncie and 12 bolt in a HT sized vehicle, but for the HK the engine and box was
exactly as it would have been in a Camaro or ChevyII except for the 1967 pre-AIR carby fitted (in the USA all 1968 engines got AIR carbs, even our 1968 327 Impalas and Parisiennes got AIR carbs, AIR was basically ADR27 here introduced in 8-9/73) and the bits changed to make the engine fit (sump and an exhaust manifold). Even the distributor was the same unlike all other HK-HG SBC engines. Also for the HK GTS327 GMH had to have Dunlop make special tyres for the car as a tyre to match the performance of the car did not exist at the time in Australia, a more powerful engine again may have seen added cost here too. And as we know in hindsight the HK wheel and tailshaft were not up to the task of what was required so maybe more cost.
GMH also aimed the GTS327's price deliberately below the GT, and wanted the GTS327 to be seen as equivalent in performance to a GT. They even had Falcon GTs present at the Lang Lang Press test day (a week before the Surfers Paradise release). We now know that the GT was no match for the GTS327.
The GTS350 was a match for the GT-HO, even the hobbled Press Test cars were faster than an XW GT-HO to 50mph. In Sports Car World's December 1969 test of the XW GT-HO quote: "Line it up at the traffic lights and you can still get done by a 350 GTS Monaro - which is cheaper by a very large margin. And you can be held all the way up to the open road speed limit (prima facie
or absolute)." This is talking about the GTS350's they tested that were deliberately masked in their true potential that only managed to achieve average standing quarters of 15.8s and 0-100mph of 18.9s (SCW posted the GTS's test figures next to the GT-HO which showed 14.8s quarter and 16.7s). A properly tuned GTS350 only ever made it into the Press's hands twice (two different HG GTS350's), and they never got to do acceleration figures, but commented that the car was so much faster than the cars they tested originally and was very close to the GT-HO (and GT-HO II). There was never published road tests of a GTS350 until AMC Magazine tested a properly tuned and virtually untouched 40,000 mile car in about 2010 using historical testing methods (car even had its original clutch in it). They achieved standing quarter mile average of 14.78s and 0-100mph of 15.95s which is all but as quick as even the GT-HO III (Wheels 10/71 1/4 mile 14.7s and 0-100mph 15.2s), although that comparison is all but irrelevant as the HG GTS350 was killed off before 1971 came around and the Phase III had only just been released a few months earlier.
Edited by user Thursday, October 18, 2018 3:28:13 PM(UTC)
| Reason: Not specified
