Joined: 7/09/2016(UTC) Posts: 163  ![Australia Australia]() Location: Blackbutt Queensland Thanks: 9 times Was thanked: 4 time(s) in 4 post(s)
Byron, I came across the details of a 7/71 HG Van in NZ. It had a 202 in it. I don't know where this Van is now as the tags were removed many years ago?
FIRST NZ Rego 20th June 1979. Imported in to NZ June 79. JF4522 (Copied from the NZ Ownership Papers)
ENGINE NUMBER QL1718 (3300) (Copied from the NZ Ownership Papers)
CHASSIS: 8017098203248 (Copied from the NZ ownership Papers)
1st Tag: HOLDEN HG PANEL VAN AHG45374B 4450lbs 7/71
2nd Tag: MODEL HG80170A BODY: 21347B TRIM: 1821 14A PAINT: 568 13134
Vin: 80170GH203248
Add these details to your collection Byron. Cheers, Ron
48 215 |
Thanks: 1 times Was thanked: 607 time(s) in 574 post(s)
Thanks Ron The engines in these are odd, initially they seem to have had GL, GM, GD, GE engines but some have turned up with Q engines. That is the 718th HQ engine number so at a stretch may be correct. Edited by user Sunday, 15 September 2019 4:47:49 PM(UTC)
| Reason: Not specified |
Joined: 3/07/2019(UTC) Posts: 65 ![New Zealand New Zealand]() Thanks: 4 times
Originally Posted by: nineteenfortyeight  Byron, I came across the details of a 7/71 HG Van in NZ. It had a 202 in it. I don't know where this Van is now as the tags were removed many years ago?
Vin: 80170GH203248
I know who has this pv Do you have the ownership papers? How did you come across these details? I have an hg panel van myself with a 253
The engine number should be GL not QL. My mistake. I'll see what I can find out. Where is it now? |
48 215 |
Originally Posted by: nineteenfortyeight  The engine number should be GL not QL. My mistake. I'll see what I can find out. Where is it now? My friend has it Do you have the ownership papers? How did you get the details on the Pv?
I was emailed the details off the tags and ownership papers but am not able to verify who actually has them. Where are you located Liquifaction? |
48 215 |
Originally Posted by: nineteenfortyeight  I was emailed the details off the tags and ownership papers but am not able to verify who actually has them. Where are you located Liquifaction? It would be good to reunite the tags and ownership papers with the van if possible Whoever contacted you must know something?
I think the engine number maybe GL17180.
It was still registered on 14th Feb 2018 as LEE993. |
