HTUTE400 Offline
#1 Posted : Wednesday, 22 July 2020 1:16:19 PM(UTC)
HTUTE400
Hi guys
Does anyone know what the amperage rating is for the relay on a HK power window set up ?
The workshop manual shows one relay but doesn’t specify amperage.
Thanks in advance.
gm5735 Offline
#2 Posted : Wednesday, 22 July 2020 8:03:43 PM(UTC)
gm5735
A relay current rating of 30Amps DC will be adequate. Make sure what you get has 30A DC rating, not AC.
You will also need a circuit breaker or fuse close to the starter motor solenoid positive terminal. The fuse or circuit breaker should also be 25 or 30 amps.
HTUTE400 on 23/07/2020(UTC)
