SLENUT Offline
#1 Posted : Tuesday, 6 October 2020 6:00:25 PM(UTC)
SLENUT
Hello all
Years ago i got a rebuilt Rochester from Hume perfomance, the right one for a VB 5 litre manual.
I also decided to get an electric choke for it. However i put the wire to the wiper motor and has made the wiper motor very slow.
Where should i have this wire on? I believe i need 12V to make it work properly?
The Commodore SL/E fanatic.
#2 Posted : Tuesday, 6 October 2020 9:50:44 PM(UTC)
Originally Posted by: SLENUT Go to Quoted Post
Hello all
Damo.. you need to a find a 12v 'ignition' on wire anywhere in the engine bay.
do NOT use the coil lead as some do.. as it is a resistor type power feed on VBs
(which come with points ignition) but any 12v feed that comes live when you
turn the ignition on
ps.. the wiper motor is not a good idea as the choke pulls a few amps &
don't fuse the choke with a 1A fuse either. Needs 10 amps
here is mine on the race car (right click and view pic for a closer shot)
.. VKs have a nice handy fusebox close by Whistle
Edited by user Tuesday, 6 October 2020 9:52:46 PM(UTC)  | Reason: Not specified
SLENUT Offline
#3 Posted : Wednesday, 7 October 2020 9:26:59 AM(UTC)
SLENUT
Thought they maybe the case, hmmm. I'll have a looksy and find a place for it. I've read about the pink wire can be used.
#4 Posted : Wednesday, 7 October 2020 1:45:55 PM(UTC)
pink wire is your power feed to the coil. I wouldn't use it
on a VB it is a resistor wire.. won't run your ignition AND the coil
Have you got a Quaddy with the idle nudger/anti-dieseling motor on the side of it on the 308?
(standard factory fitment ...) From memory , that has a full 12v feed that runs when
the ignition is on. That is.. when you start and run the engine, that idle nudger is always
powered. You have a tester or multimeter you can check the volts on that circuit?
SLENUT Offline
#5 Posted : Wednesday, 7 October 2020 3:09:27 PM(UTC)
SLENUT
No i don't have the anti dieseling solenoid.
#6 Posted : Wednesday, 7 October 2020 3:37:42 PM(UTC)
Was thanked: 242 time(s) in 216 post(s)
All VBs had an idle stop solenoid as standard. Why anybody would remove it is beyond me.
Having said that. Even if the solenoid is no more, its wiring harness might still be there. It would be a good supply for the choke.
Smitty2 on 7/10/2020(UTC)
#7 Posted : Wednesday, 7 October 2020 5:14:15 PM(UTC)
yes... good pickup on that
Premier 350 Offline
#8 Posted : Wednesday, 7 October 2020 7:52:32 PM(UTC)
Premier 350
Slightly off topic, but I had an electric choke Holley on my HQ. Since I was running a HEI ignition, I used a relay to give 12V to the HEI and also power the choke. The original resistance ignition wire was shortened and triggered the relay. Never a problem in 10 years and 4000 miles. In your case you could use the 12V from the wiper to trigger the relay and run separate wiring for the high amperage draw of the choke.
SLENUT Offline
#9 Posted : Wednesday, 7 October 2020 8:34:40 PM(UTC)
SLENUT
Reason it doesn't have anti dieseling solenoid cause sometime in its life its been bastardised to buggery. Had a Holley and torker manifold and all pollution gear removed when i got it 20 years ago.
#10 Posted : Friday, 9 October 2020 12:34:11 PM(UTC)
Why use a relay? Why not just take 12v straight from any 12v that’s convenient?
#11 Posted : Friday, 9 October 2020 1:17:05 PM(UTC)
Because of the current draw. The total current of the HEI plus the electric choke element is going to be in the region of 20-25 amps continuous. This is a bit more than the old 70s wiring & ignition switch is going to be happy with.
By running a relay you will improve performance (less voltage loss) & improve reliability.
Edited by user Friday, 9 October 2020 1:21:52 PM(UTC)  | Reason: Not specified
Smitty2 on 9/10/2020(UTC)
#12 Posted : Saturday, 10 October 2020 7:49:20 AM(UTC)
Of course. Sorry I was just off night shift. Brain doesn’t work too well then.
This page was generated in 0.158 seconds.
