Hey guys, Can anyone tell me what break booster my mid August built 1968 hk premier left the factory with?
186 powerglide car H5....eg pbr vh-???
Any help would be appropriated
Thanks: 2 times Was thanked: 27 time(s) in 26 post(s)
I had a early 8/68 with lever action, but have seen some around the same time with direct.
Joined: 16/04/2014(UTC) Posts: 768 Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
Originally Posted by: Warren Turnbull I had a early 8/68 with lever action, but have seen some around the same time with direct. If the RH inner fender is original it may tell the story.
Thanks Warren,
My subframe is original, I’m the second owner of the car, it has the indentation on the skirt...
I currently have a VH- 312 which is wrong because it won’t allow the big blue check valve ..thinking I need a VH -300 or VH-305 to allow the 7/8 blue check valve.?...
