Joined: 11/03/2021(UTC) Posts: 4 ![New Zealand New Zealand]() Location: Otago
Hi, I am wondering if anyone has a modern paint code for Narrogin Green. I am about to do some paining but can't seem to find a colour match here in NZ. My HD has a darker green roof called (I think) Brunswick green, this doesn't come up as a holden colour either, has anyone else had this colour used? It was on from new. Thanks, Graeme.
Thanks: 1 times Was thanked: 255 time(s) in 246 post(s)
Narrogin Green was colour code 526-6833. 526 is solid Acrylic Lacquer, but you may have a different line against this like 585 as it did change. The formula is:
TINTER SETTING 01012 273 05440 295 05431 335 00743 404 00742 500
I don't have Brunswick Green in any paint books, if it is that colour it might be hard. There is a Fleet colour called Brunswick but the code is an enamel code so will either be an early GMH colour or not GMH at all. |
Joined: 2/03/2005(UTC) Posts: 459 ![Australia Australia]() Thanks: 1 times Was thanked: 4 time(s) in 4 post(s)
Graeme, contact “ cartouchuppaint “ they have Holden Paint, Mid Brunswick Green 04783, 1972-1973 exterior. They maybe able to supply a colour sample on line ??? AL.
Thanks for the replies, should be able to get somewhere with this now.
