Hi guys first time member and post, I have a leaky rear axel, I'd like to know if I have to remove the backing plate salisbury 10 bolt, to take the axel out as I wanted to take it some where to Have a new bearing and seal put on
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
Is it on a Holden or a Camaro? On a Holden they use a normal Holden style attachment to the axle tube just like a banjo, but a Camaro will have a C-clip that needs the rear plate removed to free up the axle. |
It's on a Holden' I just wasn't sure if I had to take the cover plate off and undo something in there. Do I have to take it off to pull the axel out
Same as a banjo or a HQ-VK Salisbury. |
I've never pulled an axel out before, I know my way around a transmission and motor but the diff is all new to me. Some information would be greatly appreciated
Joined: 2/03/2018(UTC) Posts: 105 Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
Jack & chassis stand Wheel off Drum off 4 x 9/16 nuts & spring washers off the retainer plate Hammer, slide hammer what ever you need
I have an old axle cut to about 300mm with the studs knocked out. Put it on one wheel stud, with wheel nut on loose, grab cut shaft of axle (with left hand) & belt the flange below where it's bolted to your axle, usually 2 hits does it
Joined: 21/04/2017(UTC) Posts: 293 Location: Tolmie Thanks: 2 times Was thanked: 24 time(s) in 24 post(s)
I find it easy to put drum on backwards and nuts on loose with flat end towards drum. Works great as a slide hammer.
1 user thanked KBM for this useful post.
Joined: 20/03/2011(UTC) Posts: 132 Was thanked: 16 time(s) in 16 post(s)
I find that the full range of GMH workshop manuals works fine every time. And specifically VK Wagon with EFI & Axle M39313 June, 1985 Fading Gray to White there may be earlier Axle manuals. Edited by user Thursday, 19 May 2022 11:15:33 AM(UTC)
| Reason: Not specified
