3 Pages123>
NEDLOH Offline
#1 Posted : Sunday, 21 August 2022 1:58:57 PM(UTC)
NEDLOH
Afternoon All, I have a 307 chev engine 3914636 engine number is 30746*** K10 27.
I would like information on which type of vehicle this may have been in and the cars assembly plant please?
Is this a later number engine out of Dandenong? Those of you that know all the numbers and plant information where do you find it? I have looked and looked.
Would be exciting if it could have been in a Monaro?
Thanks in advance.
#2 Posted : Monday, 22 August 2022 6:47:05 AM(UTC)
It could have been from a Monaro, but more than likely from any other Dandenong assembled automatic HK (or possibly even HT) except 81837 which includes Belmont, Kingswood, Premier GTS and Brougham (HK only) in any body style. By my memory it is later HK ie basically 1969 but without seeing its numbers can't be sure.
#3 Posted : Monday, 22 August 2022 5:42:17 PM(UTC)
See attached link FYI:
https://www.fastlane.com...ok-com-and-similar.aspx
I don't help anyone privately much anymore either after what some fool is putting HHS through, so any help is only in the public domain.
NEDLOH Offline
#4 Posted : Tuesday, 23 August 2022 6:06:21 PM(UTC)
NEDLOH
Sorry I am indeed a Fastlane novice, I didnt know how else to send a message but I have found the reply tab now
#5 Posted : Wednesday, 24 August 2022 7:06:55 AM(UTC)
All good, even if I would help privately I couldn't in your case as your email came from gmail.com which is one of those I cannot reply to as per that attached link, they bounce back.
Telstra Offline
#6 Posted : Friday, 26 August 2022 9:30:20 AM(UTC)
Telstra
Hello all, i'm newbe to this forum, So i'm hoping someone can help. I would like to know the history and details behind a 307 engine. i'm not sure if its required or appropriate to share the full number on such a public forum. happy to share part thereof if it helps
#7 Posted : Friday, 26 August 2022 12:51:11 PM(UTC)
If you want the info you'll need to put it here as that is the only way I'll help with that sort of thing. As stated above I don't do it privately any more.
NEDLOH Offline
#8 Posted : Friday, 26 August 2022 1:15:14 PM(UTC)
NEDLOH
Thanks HK1837, should I just post photos of all the numbers I can find on the block? Is that ok to do? I see previous people are little cagey about this?
What told you it was auto, did have an auto on it when I got some 20 years ago.
Also, what is some fool putting HHS through? I have been dealing with Ben concerning another car of mine, great guy, big help.
Thanks again, have a good weekend to All!
#9 Posted : Friday, 26 August 2022 3:43:07 PM(UTC)
Just give me the engine number, leave off the last digit of the GMH number if you like.
I know its auto as it was assembled and first run (on gas) on 27th October 1967. GMH didn't need any manual engines until GTS production started about the first week of July 1968 so they weren't made until somewhere starting around April 1968, and they were all over by mid July 1968 as that was when the North American engine plants retooled for 1969 model engine production which started early August 1968. So all HK-HT 307 engines were produced in that 8/67 through to 7/68 period. Your date code on the side of the block will be sometime prior to 27th October 1967 by one day up to a few months.
Ben will probably tell the story in good time.
Telstra Offline
#10 Posted : Friday, 26 August 2022 6:28:59 PM(UTC)
Telstra
Hello HK1837, thanks in advance for your help. I would like to know the history and details behind the following 307 engine please. Cast # GM 391463x, Eng# 30716692 k05 22. Any idea what it could be out of?
#11 Posted : Friday, 26 August 2022 6:41:01 PM(UTC)
Pagewood assembled HK close to the end of HK. I’ll have a better look later and see if I have the date the same already recorded.
I didn't have 0522 recorded so I can't tell you if it is a known auto or known manual date code.
Edited by user Monday, 29 August 2022 4:14:32 PM(UTC)  | Reason: Not specified
NEDLOH Offline
#12 Posted : Sunday, 28 August 2022 9:31:41 AM(UTC)
NEDLOH
Thanks for that HK1837. numbers are 3914636 30746207 K10 27.
Do you have a book or database for you refer to?
Nice of you to spend your time answering everyones questions.
bazza30555 Offline
#13 Posted : Monday, 29 August 2022 12:30:17 PM(UTC)
bazza30555
Hi HK
Am i right in thinking that only 307 engines made in the months of Aug to Dec are all 1967 production.
Cheers Bazza.
#14 Posted : Monday, 29 August 2022 4:16:10 PM(UTC)
I don't have enough Dandenong cars recorded to say for certain, but I believe this is from a later HK possibly the end of 1968 or early 1969 or thereabouts. Has to be from an auto car so best bet is a Brougham.
bazza30555 Offline
#15 Posted : Monday, 29 August 2022 5:01:07 PM(UTC)
bazza30555
307451xx car built in the 3rd week of Dec if it helps
#16 Posted : Monday, 29 August 2022 5:46:40 PM(UTC)
Originally Posted by: bazza30555 Go to Quoted Post
Hi HK
Cheers Bazza.
Yes, have to be. 1968 engines are one of a kind. They have the new large mains, filler neck at the front, alternator hanging off the LHS exhaust manifold, short water pump and PCV in the rocker covers with bare end heads. The engines changed dramatically for 1969 with accessory bolt heads, long water pumps, alternator over the RH rocker cover and oil filler in the rocker cover. So if a 1968 engine had an engine date code between August and December it was assembled in 1967.
Telstra Offline
#17 Posted : Monday, 29 August 2022 9:48:45 PM(UTC)
Telstra
Hello HK1837, thank for your insight on this subject but unless i missed it i feel that my question is not yet answered.. I'm casing the history and details behind the following 307 engine please.
Cast # GM 3914636, Eng# 30716692 k05 22. TIA
#18 Posted : Tuesday, 30 August 2022 8:48:59 AM(UTC)
See post 11 above.
Telstra on 30/08/2022(UTC)
bazza30555 Offline
#19 Posted : Saturday, 17 September 2022 4:42:37 PM(UTC)
bazza30555
The earliest Victorian 307 I have recorded is 45156k0708, does anyone have anything earlier.
#20 Posted : Saturday, 17 September 2022 7:01:56 PM(UTC)
There is maybe 4500-4800 or so earlier than that, the rest to make up to 5156 will be 327's. I do have at least one 30740xxx number as a photo but have earlier ones recorded.
Edited by user Sunday, 18 September 2022 7:10:52 AM(UTC)  | Reason: error
3 Pages123>
This page was generated in 0.152 seconds.
