Joined: 21/12/2022(UTC) Posts: 3 Location: Shepparton
Hi all I have modded a Vs fuel tank to fit my Hj and I’ve read on a couple forums that you can get the Vs sender to run the Hj gauge just wondering if anyone knows how?
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
Two ways I know of. This sort of thing is the easiest, just have to check that the sender and gauge ranges are both catered for. https://www.ebay.com.au/itm/164045864880 |
Unfortunately doesn’t look like it quite reaches the range of the vs sender. 282-40 according the chart I have. Not sure what the means lol but the Hj is listed as 73-10. Cheers Edited by user Thursday, 22 December 2022 12:44:41 PM(UTC)
| Reason: Not specified
That was an example. There are plenty of others. Yogi has one: https://www.yogisinc.com/YSN34 |
Oh yep I see will look into thank you. Much appreciated.
