Hi,
Is a solid axel differential out of a V6 VS Executive sedan the same as the VR/VS ute one?
Mauser
Joined: 2/03/2018(UTC) Posts: 105 Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
Mauser The centre is, (depending on l.s.d), but the housing/mounting is different. You can use a wagon diff into a ute, but sedans have different bracketry
Hi,
thanks for the information
Mauser
Joined: 6/07/2019(UTC) Posts: 356 Location: bayside Melbourne Thanks: 222 times Was thanked: 27 time(s) in 27 post(s)
Mauser The centre is, (depending on l.s.d), but the housing/mounting is different. You can use a wagon diff into a ute, but sedans have different bracketry as is the case since VB days.... sedans have different brackets/mounts to wagons |
