All
I came across an oddity yesterday, and discussed it with Ben S.
In amongst the HQ records there is a number (like dozens) of base model cars, all credited as sold by United Motors Adelaide which suggests all FLEET order. Most are 6cyl Belmont utility, most are M15 3spd but there are a few that are Belmont sedan/wagon/van plus a couple of autos. they all seem to have front disc brakes but no other mechanical options. A few rare ones are listed with QD engine numbers but those may be data entry errors (records are full of these for engine numbers).
The records use a coding system for the mechanical options. For the engines in HQ, 2 is QD/QE, 3 is QL/QM, 5 is QR/QS, 7 is QT and 6 is QU.
These wierdo cars all have a 4 which doesn't exist in HQ for engine coding.
Been scratching my head to figure out what it might be. If the couple with QD engine numbers are correct then its some odd high comp 173, but that doesn't gel. It is possible they are special order 130ci (ie QA prefix) engines maybe?
Attached is a BODY ID plate for one of them, it also has an error on the BODY line where whomever typed it put LJ instead of HQ. It was 4511 Golden yellow which was a fleet colour used by a number of companies including:
Allen Bros. (Asphalting) P/L (SA).
Ansett Freight Express.
Aveling Barford Trailers.
Department of Main Roads (no idea what State).
Emoleum Australia Pty Ltd (NSW).
Hertz Rent-A-Truck.
Mitre 10 Group (QLD).
There are a few more companies with Golden Yellow but a different formula. My money is on maybe Ansett or the DMR if that is in South Australia.
Any thoughts? Anyone seen one of these vehicles in South Australia?
Edited by user Wednesday, July 26, 2023 11:34:53 AM(UTC)
| Reason: Not specified
